Test NVIDIA GeForce RTX 4090 Laptop GPU w Razer Blade 16 - Mocna premiera architektury Ada Lovelace w notebookach
- 1 - Test Razer Blade 16 z NVIDIA GeForce RTX 4090 Laptop GPU
- 2 - NVIDIA GeForce RTX 4090 Laptop GPU i architektura Ada Lovelace
- 3 - Test Razer Blade 16 - jakość wykonania, wnętrze notebooka
- 4 - Test Razer Blade 16 - specyfikacja techniczna
- 5 - Test Razer Blade 16 - badanie jakości matrycy
- 6 - Test Razer Blade 16 - miejsca pomiarowe
- 7 - Test Razer Blade 16 - 3DMark Time Spy
- 8 - Test Razer Blade 16 - 3DMark Speed Way
- 9 - Test Razer Blade 16 - 3DMark DirectX Ray Tracing
- 10 - Test Razer Blade 16 - Assassin's Creed Valhalla
- 11 - Test Razer Blade 16 - Call of Duty: Modern Warfare II
- 12 - Test Razer Blade 16 - Control
- 13 - Test Razer Blade 16 - Cyberpunk 2077
- 14 - Test Razer Blade 16 - Dying Light 2
- 15 - Test Razer Blade 16 - Forza Horizon 5
- 16 - Test Razer Blade 16 - Marvel's Spider-Man Remastered
- 17 - Test Razer Blade 16 - Metro Exodus Enhanced Edition
- 18 - Test Razer Blade 16 - Red Dead Redemption 2
- 19 - Test Razer Blade 16 - Quake II RTX
- 20 - Test Razer Blade 16 - The Callisto Protocol
- 21 - Test Razer Blade 16 - Watch Dogs Legion
- 22 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon Next-Gen
- 23 - Test Razer Blade 16 - Control (RT / DLSS 2)
- 24 - Test Razer Blade 16 - Cyberpunk 2077 (RT / DLSS 2)
- 25 - Test Razer Blade 16 - Dying Light 2 (RT / DLSS 2)
- 26 - Test Razer Blade 16 - Marvel's Spider-Man Remastered (RT / DLSS 2)
- 27 - Test Razer Blade 16 - Metro Exodus Enhanced Edition (DLSS 2)
- 28 - Test Razer Blade 16 - The Callisto Protocol (RT)
- 29 - Test Razer Blade 16 - Watch Dogs Legion (RT / DLSS 2)
- 30 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon Next-Gen (RT / DLSS 2)
- 31 - Test Razer Blade 16 - Cyberpunk 2077 (Skalowanie DLSS 3)
- 32 - Test Razer Blade 16 - Dying Light 2 (Skalowanie DLSS 3)
- 33 - Test Razer Blade 16 - Marvel's Spider-Man Remastered (Skalowanie DLSS 3)
- 34 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon Next-Gen (Skalowanie DLSS 3)
- 35 - Test Razer Blade 16 - Cinebench R23 (Single)
- 36 - Test Razer Blade 16 - Cinebench R23 (Multi)
- 37 - Test Razer Blade 16 - 3D Particle Movement
- 38 - Test Razer Blade 16 - Performance Test 10 (CPU)
- 39 - Test Razer Blade 16 - Performance Test 10 (Memory)
- 40 - Test Razer Blade 16 - 7-zip (Kompresja dużego pliku)
- 41 - Test Razer Blade 16 - 7-zip (Kompresja małych plików)
- 42 - Test Razer Blade 16 - 7-zip (Wydajność kompresji i dekompresji)
- 43 - Test Razer Blade 16 - Handbrake
- 44 - Test Razer Blade 16 - Corona
- 45 - Test Razer Blade 16 - V-Ray (CPU)
- 46 - Test Razer Blade 16 - V-Ray RTX (GPU)
- 47 - Test Razer Blade 16 - Blender 3.4
- 48 - Test Razer Blade 16 - Blackmagic RAW Speed
- 49 - Test Razer Blade 16 - Visual Studio 2019
- 50 - Test Razer Blade 16 - 3DMark Time Spy (akumulator)
- 51 - Test Razer Blade 16 - Assassin's Creed Valhalla (akumulator)
- 52 - Test Razer Blade 16 - Cyberpunk 2077 (akumulator)
- 53 - Test Razer Blade 16 - Blender 3.4 GPU (akumulator)
- 54 - Test Razer Blade 16 - V-Ray RTX (akumulator)
- 55 - Temperatury podzespołów - małe i duże obciążenie
- 56 - Temperatury obudowy - małe i duże obciążenie
- 57 - Głośność urządzenia - małe i duże obciążenie
- 58 - Pobór mocy - małe i duże obciążenie
- 59 - Czas pracy na zasilaniu akumulatorowym
- 60 - Undervolting układu NVIDIA GeForce RTX 4090 Laptop GPU
- 61 - Undervolting - wydajność w grach
- 62 - Test Razer Blade 16 z GeForce RTX 4090 Laptop GPU - podsumowanie
Odkąd jestem częścią załogi PurePC.pl, miałem możliwość oceny kilku ostatnich architektur NVIDII dla kolejnych generacji mobilnych układów graficznych. W momencie premiery Pascala, NVIDIA wprowadziła całą generację GPU, których specyfikacja była bliźniacza z desktopowymi odpowiednikami. Późniejsza premiera Turinga zachowała te proporcje, wprowadzając dodatkowo rdzenie RT 1. generacji oraz Tensory 2. generacji. Ampere (GeForce RTX 3000 Laptop GPU) nie była jakąś oszałamiającą architekturą - różnice w wydajności w wielu wypadkach były raczej mizerne względem wcześniejszej generacji, a dodatkowo wprowadzono totalny chaos z różnymi limitami energetycznymi. W styczniu tego roku NVIDIA zaprezentowała kolejną architekturę dla wydajnych laptopów - Ada Lovelace. Choć producent nadal stosuje fikołki przy nazwach czy limitach TGP, trzeba przyznać jedno - nowa architektura w połączeniu z procesem TSMC 4N dała w laptopach imponujący wzrost wydajności oraz efektywności energetycznej.
Autor: Damian Marusiak
NVIDIA GeForce RTX 4090 Laptop GPU to flagowy układ graficzny obecnej generacji dla przenośnych komputerów. Nie ma on jednak nic wspólnego z desktopową kartą GeForce RTX 4090. Zamiast tego zdecydowano się na zachowanie specyfikacji tożsamej z desktopowym GeForce RTX 4080. Otrzymujemy zatem niemal pełny rdzeń AD103 z 9728 rdzeniami CUDA FP32, 76 rdzeniami RT 3. generacji oraz 304 rdzeniami Tensor 4. generacji. Sama architektura Ada Lovelace jest taka sama dla desktopów jak i laptopów. Otrzymujemy zatem m.in. wydajniejsze rdzenie CUDA, przebudowane rdzenie RT do akceleracji obliczeń związanych ze śledzeniem promieni, a także nowe rdzenie Tensor z obsługą techniki Frame Generator oraz korzystających z układu Optical Flow Accelerator. Całość doprawiono 16 GB pamięci GDDR6 na 256-bitowej magistrali. Do testów otrzymaliśmy high-endowego notebooka Razer Blade 16, w którym moc układu NVIDIA GeForce RTX 4090 Laptop GPU wynosi maksymalnie 175 W. Całość opracowano w kompletnie nowej i dużo bardziej zaawansowanej litografii TSMC 4N, co pozwoliło na wpakowanie ponad 45 miliardów tranzystorów na stosunkowo niewielkiej powierzchni rdzenia graficznego AD103. Umożliwiło to na blisko 3-krotne zwiększenie gęstości upakowania tranzystorów względem rdzenia GA103 w architekturze Ampere i procesie Samsung 8 nm.
Dzisiaj spada embargo na testy nowej generacji laptopów z układami NVIDIA GeForce RTX 4090 Laptop GPU oraz GeForce RTX 4080 Laptop GPU. Na początek sprawdzamy notebooka Razer Blade 16, wyposażonego w najmocniejszy układ GeForce RTX 4090 o mocy 175 W.
W przypadku architektury Ada Lovelace nie można zapomnieć również o wsparciu dla techniki DLSS 3, którego najistotniejszą nowością jest funkcja Frame Generation, gdzie pomiędzy dwiema wyrenderowanymi już klatkami umieszczana jest trzecia, stworzona z pomocą AI i rdzeni Tensor, a do przygotowania której wykorzystano m.in. wektory ruchu z dwóch sąsiadujących po sobie klatek oraz silnika Optical Flow Accelerator. Dzięki DLSS 3 wydajność może zostać znacząco zwiększona, bez istotnego wpływu na jakość obrazu. W laptopach, gdzie ekrany mają znacznie mniejszą przekątną a tym samym gęstsze upakowanie pikseli, ewentualne różnice w obrazie będą jeszcze mniej dostrzegalne w porównaniu do dużo większych monitorów. Lista obsługiwanych gier regularnie się powiększa, a testy które przeprowadzałem w ostatnich dniach potwierdzają, że dla rynku notebooków będzie to prawdziwy "gamechanger", na który konkurencja nie ma obecnie jakiejkolwiek odpowiedzi.
NVIDIA GeForce RTX 4090 Laptop GPU | NVIDIA GeForce RTX 4080 Laptop GPU | NVIDIA GeForce RTX 3080 Ti Laptop GPU | |
Architektura | Ada Lovelace | Ada Lovelace | Ampere |
Układ graficzny | AD103 | AD104 | GA103 |
Litografia | TSMC 4N | TSMC 4N | Samsung 8 nm |
Powierzchnia | 378,6 mm² | 294,5 mm² | 496 mm² |
Tranzystory | 45,9 mld | 35,8 mld | ~22 mld |
Jednostki SP | 9728 | 7424 | 7424 |
Jednostki TMU | 304 | 232 | 232 |
Jednostki ROP | 112 | 80 | 96 |
Jednostki RT | 76 (3. gen) | 58 (3. gen) | 58 (2. gen) |
Jednostki Tensor | 304 (4. gen) | 232 (4. gen) | 232 (3. gen) |
Taktowanie Boost | Do 2040 MHz | Do 2280 MHz | Do 1590 MHz |
Pamięć | 16 GB GDDR6 (do 18 Gbps) | 12 GB GDDR6 (do 18 Gbps) | 16 GB GDDR6 (do 16 Gbps) |
Szyna pamięci | 256-bit | 192-bit | 256-bit |
Obsługa DLSS 3 | Tak | Tak | Nie |
Współczynnik TGP | Od 80 do 150 W + 25 Dynamic Boost |
Od 80 do 150 W + 25 W Dynamic Boost |
Testowany Razer Blade 16 to prawdziwie topowa konstrukcja, która oferuje wszystko co najlepsze w tej generacji. Oprócz najmocniejszego układu graficznego NVIDIA GeForce RTX 4090 Laptop GPU, na pokładzie znajdziemy również 24-rdzeniowy i 32-wątkowy procesor Intel Core i9-13950HX z rodziny Raptor Lake-HX, 32 GB pamięci RAM DDR5 5600 MHz oraz 2 TB nośnik SSD PCIe 4.0 x4 NVMe. Ekran to z kolei prawdziwa petarda - 16-calowy wyświetlacz IPS z podświetleniem Mini LED i dwiema natywnymi rozdzielczościami do wyboru. Do dyspozycji oddano bowiem rozdzielczość 3840 x 2400 pikseli z odświeżaniem 120 Hz lub 1920 x 1200 pikseli z odświeżaniem 240 Hz. Przełączanie się pomiędzy nimi odbywa się za pośrednictwem zainstalowanej aplikacji Razera, jednak każdorazowo wymaga również ponownego uruchomienia systemu Windows. Całość pracuje oczywiście na nowej wersji Okienek.
38
175
