Test karty graficznej KFA2 GeForce RTX 4090 SG - Chłodzenie jak marzenie! Wystarczy wolne 10000 złotych i cztery sloty
- 1 - Test KFA2 GeForce RTX 4090 SG - Wstęp
- 2 - Test KFA2 GeForce RTX 4090 SG - Budowa i specyfikacja
- 3 - Test KFA2 GeForce RTX 4090 SG - Platforma testowa i metodyka
- 4 - Test KFA2 GeForce RTX 4090 SG - Miejsca pomiarowe
- 5 - Test KFA2 GeForce RTX 4090 SG - 3DMark Time Spy
- 6 - Test KFA2 GeForce RTX 4090 SG - Assassin's Creed: Valhalla
- 7 - Test KFA2 GeForce RTX 4090 SG - Cyberpunk 2077
- 8 - Test KFA2 GeForce RTX 4090 SG - DOOM Eternal
- 9 - Test KFA2 GeForce RTX 4090 SG - Dying Light 2
- 10 - Test KFA2 GeForce RTX 4090 SG - Forza Horizon 5
- 11 - Test KFA2 GeForce RTX 4090 SG - God of War
- 12 - Test KFA2 GeForce RTX 4090 SG - Horizon: Zero Dawn
- 13 - Test KFA2 GeForce RTX 4090 SG - Metro Exodus
- 14 - Test KFA2 GeForce RTX 4090 SG - Red Dead Redemption 2
- 15 - Test KFA2 GeForce RTX 4090 SG - Watch Dogs: Legion
- 16 - Test KFA2 GeForce RTX 4090 SG - Wiedźmin 3: Dziki Gon
- 17 - Test KFA2 GeForce RTX 4090 SG - Cyberpunk 2077 (RT)
- 18 - Test KFA2 GeForce RTX 4090 SG - Dying Light 2 (RT)
- 19 - Test KFA2 GeForce RTX 4090 SG - Metro Exodus (RT)
- 20 - Test KFA2 GeForce RTX 4090 SG - Cyberpunk 2077 (RT i DLSS)
- 21 - Test KFA2 GeForce RTX 4090 SG - Dying Light 2 (RT i DLSS)
- 22 - Test KFA2 GeForce RTX 4090 SG - Metro Exodus (RT i DLSS)
- 23 - Test KFA2 GeForce RTX 4090 SG - Cyberpunk 2077 (RT i DLSS 3)
- 24 - Test KFA2 GeForce RTX 4090 SG - Overclocking
- 25 - Test KFA2 GeForce RTX 4090 SG - 3DMark Time Spy (OC)
- 26 - Test KFA2 GeForce RTX 4090 SG - Cyberpunk 2077 (OC)
- 27 - Test KFA2 GeForce RTX 4090 SG - Dying Light 2 (OC)
- 28 - Test KFA2 GeForce RTX 4090 SG - Red Dead Redemption 2 (OC)
- 29 - Test KFA2 GeForce RTX 4090 SG - Blender
- 30 - Test KFA2 GeForce RTX 4090 SG - DaVinci Resolve
- 31 - Test KFA2 GeForce RTX 4090 SG - Pobór mocy
- 32 - Test KFA2 GeForce RTX 4090 SG - Pomiar temperatur
- 33 - Test KFA2 GeForce RTX 4090 SG - Pomiar głośności
- 34 - Test KFA2 GeForce RTX 4090 SG - Sumaryczna wydajność
- 35 - Test KFA2 GeForce RTX 4090 SG - Sumaryczna wydajność (RT)
- 36 - Test KFA2 GeForce RTX 4090 SG - Podsumowanie
NVIDIA GeForce RTX 4090 Founders Edition, którego recenzję mogliście przeczytać na naszym portalu w pierwszej kolejności, nieprzyzwoicie wysoko zawiesiła poprzeczkę konstrukcjom autorskim. Wyraźne przebicie tego poziomu może okazać się naprawdę trudnym zadaniem. Modele przygotowane przez partnerów NVIDII okazują się jednak znacznie większe pod względem gabarytów oraz dysponują dodatkowymi wentylatorami, więc teoretycznie powinny zapewnić jeszcze niższe temperatury niż Founders Edition. Jednym z pretendentów do uzyskania tytułu najlepszej karty graficznej obecnej generacji jest monstrualny KFA2 GeForce RTX 4090 SG, którego możliwości poznacie w dalszej części artykułu...
Autor: Sebastian Oktaba
Rodzina kart graficznych NVIDIA GeForce RTX 4000 bazuje na architekturze Ada Lovelace, która przeszła szereg usprawnień względem Ampere napędzającego serię GeForce RTX 3000. Przede wszystkim dołożono znacznie więcej pamięci Cache L2, przebudowano bloki GPC, wprowadzono jednostki Tensor 4. generacji oraz jednostki RT 3. generacji. Celem nadrzędnym producenta było zmaksymalizowanie wydajności śledzenia promieni i usprawnienie techniki DLSS. Właśnie tutaj dokonano najpoważniejszych modyfikacji, bowiem DLSS 3 będzie nie tylko upscalować obraz, ale również zwielokrotniać ilość klatek animacji niwelując jednocześnie bottleneck za strony procesora. DLSS 3 działa jednak wyłącznie na układach Ada Lovelace, ponieważ wymaga nowych jednostek obliczeniowych zintegrowanych w Tensorach 4. generacji. Zastosowano również 5 nm litografię TSMC pozwalającą upchnąć 2,5x więcej tranzystorów na zbliżonej powierzchni, a dodatkowo uzyskać wysokie taktowania. Względem poprzednika można oczekiwać około 60-70% wzrostu wydajności w rasteryzacji, nawet 100% w śledzeniu promieni oraz 100-400% w DLSS.
KFA2 GeForce RTX 4090 SG jest prawdziwym kolosem, mierzącym prawie 34 centymetry i zajmującym cztery sloty w obudowie komputera. Zobaczymy jakie będzie to miało przełożenie na kulturę pracy i wydajność.
Marvel's Spider-Man Remastered PC - Test wydajności kart graficznych i procesorów. Jakie wymagania sprzętowe?
Jeżeli tempo rozrastania się sprzętu komputerowego zostanie utrzymane, to niedługo karty graficzne będą wjeżdżały do redakcji na paletach... Miałem bowiem okazję testować wcześniejsze wcielenia bohatera niniejszej recenzji, które wydawały się wówczas naprawdę potężnymi urządzeniami, jednak przy recenzowanym modelu KFA2 GeForce RTX 3080 Ti / 3090 SG wyglądają niczym ubodzy krewni z dalekiej prowincji. KFA2 GeForce RTX 4090 SG jest natomiast napakowanym sterydami koksem ubranym w wystrzałowe fatałaszki, spokojnie mogącym występować jako reprezentant wyżej pozycjonowanej rodziny Hall of Fame. Gargantuiczne rozmiary chłodzenia przyćmiewają nawet niemałego Founders Edition, dlatego przed zakupem oprócz grubości portfela, koniecznie sprawdźcie także długość obudowy. Producent pozostał natomiast wierny klasycznej formie systemu chłodzenia, wykorzystującego trzy wentylatory osiowe z możliwością przypięcia dodatkowej jednostki (znajdującej w zestawie).
RTX 4090 | RTX 3090 Ti | RTX 3090 | RX 6950 XT | |
Architektura | Ada Lovelance | Ampere | Ampere | RDNA 2.0 |
Układ graficzny | AD102 | GA102 | GA102 | NAVI 21 |
Litografia | 5 nm | 8 nm | 8 nm | 7 nm |
Rozmiar rdzenia | 608 mm² | 628 mm² | 628 mm² | 520 mm² |
Tranzystory | 76 mld | 28 mld | 28 mld | 27 mld |
Jednostki SP | 16384 | 10752 | 10496 | 5120 |
Jednostki TMU | 512 | 336 | 328 | 320 |
Jednostki ROP | 192 | 112 | 112 | 128 |
Jednostki RT | 128 | 82 | 82 | 80 |
Jednostki Tensor | 512 | 336 | 328 | - |
Taktowanie bazowe | 2235 MHz | 1560 MHz | 1395 MHz | 1925 MHz |
Taktowanie boost | 2520 MHz | 1860 MHz | 1650 MHz | 2324 MHz |
Taktowanie pamięci | 21200 MHz | 21000 MHz | 19500 MHz | 18000 MHz |
Ilość pamięci | 24 GB | 24 GB | 24 GB | 16 GB |
Typ pamięci | GDDR6X | GDDR6X | GDDR6X | GDDR6 |
Szyna pamięci | 384-bit | 384-bit | 384-bit | 256-bit |
Przepustowość | 1020 GB/s | 1000 GB/s | 937 GB/s | 576 GB/s |
Interfejs | PCI-E 4.0 x16 | PCI-E 4.0 x16 | PCI-E 4.0 x16 | PCI-E 4.0 x16 |
Współczynnik TGP | 450 W | 450 W | 350 W | 335 W |
Cena startowa | 1499 USD | 1999 USD | 1499 USD | 1099 USD |
KFA2 GeForce RTX 4090 SG jest podstawowym modelem w ofercie producenta, który skonfigurowano niemal dokładnie według wytycznych NVIDII. Bazowe taktowanie wynosi oczywiście 2235 MHz, minimalny GPU Boost ustalono na poziomie 2580 MHz, natomiast NVIDIA gwarantuje 2520 MHz. Rzeczywista częstotliwość rdzenia KFA2 GeForce RTX 4090 SG uzyskana pod długotrwałym obciążeniem wynosiła jednak 2700 MHz, podczas gdy NVIDIA GeForce RTX 4090 Founders Edition osiągała przeważnie 2745 MHz. Obowiązkowe 24 GB GDDR6X na 384-bitowej magistrali działało ze standardowym taktowaniem 21000 MHz. Finalna wydajność obydwu modeli będzie zatem praktycznie identyczna. Znacznie większe możliwości zachodzą w przypadku systemu chłodzenia oraz poprawy szeroko rozumianej kultury pracy. Chociaż Founders Edition generalnie pozytywnie zaskoczył temperaturami i poziomem głośności, znacznie potężniejszy cooler KFA2 GeForce RTX 4090 SG powinien poprawić te wyniki.
37
163
161
273
