Test NVIDIA GeForce RTX 5090 Laptop GPU w notebooku Razer Blade 16 - Premiera architektury Blackwell w laptopach
- 1 - Test Razer Blade 16 - Premiera GeForce RTX 5090 Laptop GPU
- 2 - Test Razer Blade 16 - Jakość wykonania, wnętrze
- 3 - Test Razer Blade 16 - Specyfikacja techniczna
- 4 - Test Razer Blade 16 - Badanie jakości matrycy
- 5 - Test Razer Blade 16 - Miejsca testowe
- 6 - Test Razer Blade 16 - 3DMark Time Spy
- 7 - Test Razer Blade 16 - 3DMark Steel Nomad
- 8 - Test Razer Blade 16 - 3DMark DirectX Ray Tracing
- 9 - Test Razer Blade 16 - Alan Wake II
- 10 - Test Razer Blade 16 - Assassin's Creed Shadows
- 11 - Test Razer Blade 16 - Avatar: Frontiers of Pandora
- 12 - Test Razer Blade 16 - Black Myth: Wukong
- 13 - Test Razer Blade 16 - Call of Duty Modern Warfare II
- 14 - Test Razer Blade 16 - Cyberpunk 2077
- 15 - Test Razer Blade 16 - Dying Light 2
- 16 - Test Razer Blade 16 - Forza Horizon 5
- 17 - Test Razer Blade 16 - Horizon Forbidden West
- 18 - Test Razer Blade 16 - Indiana Jones i Wielki Krąg
- 19 - Test Razer Blade 16 - Kingdom Come Deliverance II
- 20 - Test Razer Blade 16 - Kingdom Come Deliverance II
- 21 - Test Razer Blade 16 - Marvel's Spider-Man 2
- 22 - Test Razer Blade 16 - Red Dead Redemption 2
- 23 - Test Razer Blade 16 - Silent Hill 2
- 24 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon
- 25 - Test Razer Blade 16 - Alan Wake II (RT)
- 26 - Test Razer Blade 16 - Assassin's Creed Shadows (RT)
- 27 - Test Razer Blade 16 - Black Myth: Wukong (RT)
- 28 - Test Razer Blade 16 - Cyberpunk 2077 (RT)
- 29 - Test Razer Blade 16 - Dying Light 2 (RT)
- 30 - Test Razer Blade 16 - Indiana Jones i Wielki Krąg (RT)
- 31 - Test Razer Blade 16 - Marvel's Spider-Man 2 (RT)
- 32 - Test Razer Blade 16 - Metro Exodus Enhanced Edition (RT)
- 33 - Test Razer Blade 16 - Silent Hill 2 (RT)
- 34 - Test Razer Blade 16 - Quake II RTX (RT)
- 35 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon (RT)
- 36 - Test Razer Blade 16 - Cyberpunk 2077 (RT + MFG)
- 37 - Test Razer Blade 16 - Cyberpunk 2077 (RT + MFG + Input lag)
- 38 - Test Razer Blade 16 - Cinebench R23 (Single)
- 39 - Test Razer Blade 16 - Cinebench R23 (Multi)
- 40 - Test Razer Blade 16 - Cinebench 2024 (Single)
- 41 - Test Razer Blade 16 - Cinebench 2024 (Multi)
- 42 - Test Razer Blade 16 - 3DF Zephyr
- 43 - Test Razer Blade 16 - 3D Particle Movement
- 44 - Test Razer Blade 16 - DigiCortex
- 45 - Test Razer Blade 16 - Corona
- 46 - Test Razer Blade 16 - V-Ray
- 47 - Test Razer Blade 16 - 7-zip (Duży plik)
- 48 - Test Razer Blade 16 - 7-zip (Mały plik)
- 49 - Test Razer Blade 16 - 7-zip (Wydajność)
- 50 - Test Razer Blade 16 - Handbrake
- 51 - Test Razer Blade 16 - POV-Ray
- 52 - Test Razer Blade 16 - Performance Test (CPU)
- 53 - Test Razer Blade 16 - Performance Test (Memory)
- 54 - Test Razer Blade 16 - Blender
- 55 - Test Razer Blade 16 - VeraCrypt
- 56 - Test Razer Blade 16 - y-cruncher
- 57 - Test Razer Blade 16 - Kraken Javascript
- 58 - Test Razer Blade 16 - Microsoft 365
- 59 - Test Razer Blade 16 - AI Neural Engine
- 60 - Test Razer Blade 16 - UL Procyon Stable Diffusion XL
- 61 - Test Razer Blade 16 - Blackmagic RAW Speed
- 62 - Test Razer Blade 16 - Visual Studio 2022
- 63 - Test Razer Blade 16 - Temperatury podzespołów
- 64 - Test Razer Blade 16 - Wygrzewanie procesora
- 65 - Test Razer Blade 16 - Temperatury obudowy
- 66 - Test Razer Blade 16 - Głośność urządzenia
- 67 - Test Razer Blade 16 - Pobór mocy
- 68 - Test Razer Blade 16 - Czas pracy na zasilaniu akumulatorowym
- 69 - Test Razer Blade 16 - Alan Wake II (Akumulator)
- 70 - Test Razer Blade 16 - Assassin's Creed Shadows (Akumulator)
- 71 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon (Akumulator)
- 72 - Test Razer Blade 16 - Cinebench 2024 Multi (Akumulator)
- 73 - Test Razer Blade 16 - V-Ray (Akumulator)
- 74 - Test Razer Blade 16 - Podsumowanie
Jedną z ważniejszych składowych procedury testowej jest zbadanie kultury pracy. Podczas pomiarów temperatura otoczenia wynosiła 25 stopni Celsjusza (+/- 1 stopień). Pierwszy test polega na sprawdzeniu temperatur obudowy oraz podzespołów w trakcie małego obciążenia. Co rozumiemy pod pojęciem "małe obciążenie"? Jest to po prostu standardowe użytkowanie laptopa bez włączania gier lub programów do obróbki. Test odbywa się w następujący sposób: przy użyciu pirometru laserowego sprawdzamy najpierw temperatury na pulpicie roboczym. Wartości pochodzą z 9 miejsc: 3 u góry, 3 po środku oraz 3 na dole. Następnie odwracamy laptop, aby w identyczny sposób sprawdzić temperatury spodu.
Zjawisko "thermal throttlingu" polega na obniżeniu taktowania sprzętu komputerowego (karty graficznej lub procesora) w momencie zbyt dużego wydzielania ciepła. Pomaga to w obniżeniu temperatur tych podzespołów w celu zapobiegnięcia ich uszkodzeniu. Zbytnie przegrzanie się podzespołów znacznie skraca ich żywotność, więc użycie tego zabezpieczenia na pewno ma swoje plusy. Niemniej jednak trudno nie brać pod uwagę minusów, a zwłaszcza jednego, który rzutuje na cały sprzęt. Skoro obniżanie temperatur odbywa się poprzez zdławienie taktowań podzespołów, to musi to wiązać się ze zmniejszeniem wydajności np. w grach lub programach użytkowych. Jeśli jednak zastosowane chłodzenie w notebooku daje radę, wówczas nie musimy martwić się tym niekorzystnym zjawiskiem. Kiedy objawia się tzw. "thermal throttling"? Na to pytanie nie ma jednoznacznej odpowiedzi, ponieważ producenci ustawiają w BIOSie różne wartości krytyczne, po przekroczeniu których następuje obniżanie taktowania. W niektórych skrajnych przypadkach licznik może być ustawiony nawet na 70-75 stopni, jednak najczęściej oprogramowanie odpowiednio reaguje po przekroczeniu 90 stopni. W odświeżonej procedurze testowej, wygrzewanie odbywa się w grze Cyberpunk 2077.
W grze Cyberpunk 2077, laptop Razer Blade 16 nie osiągał jakiś przesadnie wysokich temperatur dla procesora oraz układu graficznego, ale nie są to także niskie wartości. Jest ciepło, nawet bardzo, ale jak na standardy laptopów - nie najgorzej, zwłaszcza że nowy Razer Blade 16 jest dość smukłym urządzeniem. Procesor AMD Ryzen AI 9 HX 370 rozgrzewał się do maksymalnie 85 stopni, choć z drugiej strony - ten komponent miał mocno obniżony limit mocy, średnio w okolicach 45 W, co miało niebagatelny wpływ na temperatury. Układ graficzny NVIDIA GeForce RTX 5090 Laptop GPU osiągał 80 stopni, a jego taktowanie realnie w teście sięgało niespełna 1900 MHz. Generalnie w wielu grach, laptop Razer Blade 16 miał problem z przebiciem bariery 2000 MHz i pod tym względem poprzednik wypadał nieco lepiej (częściej jednak także był w stanie dobijać do 175 W, w nowym Blade 16 ze względu na procesor, 155 W z Dynamic Boost to już absolutne maksimum, a często było to nawet mniej niż 155 W).
Temperatury procesora (Cyberpunk 2077)
Spoczynek / Obciążenie
GeForce RTX 5090 Laptop 155 W
GeForce RTX 4090 Laptop 175 W
GeForce RTX 4080 Laptop 175 W
GeForce RTX 4070 Laptop 140 W
Intel Core Ultra 9 185H (16C/22T)
GeForce RTX 4090 Laptop 125 W
Temperatury układu graficznego (Cyberpunk 2077)
- 60
- 61
- 62
- 63
- 64
- 65
- 66
- 67
38
175
