Test NVIDIA GeForce RTX 5090 Laptop GPU w notebooku Razer Blade 16 - Premiera architektury Blackwell w laptopach
- 1 - Test Razer Blade 16 - Premiera GeForce RTX 5090 Laptop GPU
- 2 - Test Razer Blade 16 - Jakość wykonania, wnętrze
- 3 - Test Razer Blade 16 - Specyfikacja techniczna
- 4 - Test Razer Blade 16 - Badanie jakości matrycy
- 5 - Test Razer Blade 16 - Miejsca testowe
- 6 - Test Razer Blade 16 - 3DMark Time Spy
- 7 - Test Razer Blade 16 - 3DMark Steel Nomad
- 8 - Test Razer Blade 16 - 3DMark DirectX Ray Tracing
- 9 - Test Razer Blade 16 - Alan Wake II
- 10 - Test Razer Blade 16 - Assassin's Creed Shadows
- 11 - Test Razer Blade 16 - Avatar: Frontiers of Pandora
- 12 - Test Razer Blade 16 - Black Myth: Wukong
- 13 - Test Razer Blade 16 - Call of Duty Modern Warfare II
- 14 - Test Razer Blade 16 - Cyberpunk 2077
- 15 - Test Razer Blade 16 - Dying Light 2
- 16 - Test Razer Blade 16 - Forza Horizon 5
- 17 - Test Razer Blade 16 - Horizon Forbidden West
- 18 - Test Razer Blade 16 - Indiana Jones i Wielki Krąg
- 19 - Test Razer Blade 16 - Kingdom Come Deliverance II
- 20 - Test Razer Blade 16 - Kingdom Come Deliverance II
- 21 - Test Razer Blade 16 - Marvel's Spider-Man 2
- 22 - Test Razer Blade 16 - Red Dead Redemption 2
- 23 - Test Razer Blade 16 - Silent Hill 2
- 24 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon
- 25 - Test Razer Blade 16 - Alan Wake II (RT)
- 26 - Test Razer Blade 16 - Assassin's Creed Shadows (RT)
- 27 - Test Razer Blade 16 - Black Myth: Wukong (RT)
- 28 - Test Razer Blade 16 - Cyberpunk 2077 (RT)
- 29 - Test Razer Blade 16 - Dying Light 2 (RT)
- 30 - Test Razer Blade 16 - Indiana Jones i Wielki Krąg (RT)
- 31 - Test Razer Blade 16 - Marvel's Spider-Man 2 (RT)
- 32 - Test Razer Blade 16 - Metro Exodus Enhanced Edition (RT)
- 33 - Test Razer Blade 16 - Silent Hill 2 (RT)
- 34 - Test Razer Blade 16 - Quake II RTX (RT)
- 35 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon (RT)
- 36 - Test Razer Blade 16 - Cyberpunk 2077 (RT + MFG)
- 37 - Test Razer Blade 16 - Cyberpunk 2077 (RT + MFG + Input lag)
- 38 - Test Razer Blade 16 - Cinebench R23 (Single)
- 39 - Test Razer Blade 16 - Cinebench R23 (Multi)
- 40 - Test Razer Blade 16 - Cinebench 2024 (Single)
- 41 - Test Razer Blade 16 - Cinebench 2024 (Multi)
- 42 - Test Razer Blade 16 - 3DF Zephyr
- 43 - Test Razer Blade 16 - 3D Particle Movement
- 44 - Test Razer Blade 16 - DigiCortex
- 45 - Test Razer Blade 16 - Corona
- 46 - Test Razer Blade 16 - V-Ray
- 47 - Test Razer Blade 16 - 7-zip (Duży plik)
- 48 - Test Razer Blade 16 - 7-zip (Mały plik)
- 49 - Test Razer Blade 16 - 7-zip (Wydajność)
- 50 - Test Razer Blade 16 - Handbrake
- 51 - Test Razer Blade 16 - POV-Ray
- 52 - Test Razer Blade 16 - Performance Test (CPU)
- 53 - Test Razer Blade 16 - Performance Test (Memory)
- 54 - Test Razer Blade 16 - Blender
- 55 - Test Razer Blade 16 - VeraCrypt
- 56 - Test Razer Blade 16 - y-cruncher
- 57 - Test Razer Blade 16 - Kraken Javascript
- 58 - Test Razer Blade 16 - Microsoft 365
- 59 - Test Razer Blade 16 - AI Neural Engine
- 60 - Test Razer Blade 16 - UL Procyon Stable Diffusion XL
- 61 - Test Razer Blade 16 - Blackmagic RAW Speed
- 62 - Test Razer Blade 16 - Visual Studio 2022
- 63 - Test Razer Blade 16 - Temperatury podzespołów
- 64 - Test Razer Blade 16 - Wygrzewanie procesora
- 65 - Test Razer Blade 16 - Temperatury obudowy
- 66 - Test Razer Blade 16 - Głośność urządzenia
- 67 - Test Razer Blade 16 - Pobór mocy
- 68 - Test Razer Blade 16 - Czas pracy na zasilaniu akumulatorowym
- 69 - Test Razer Blade 16 - Alan Wake II (Akumulator)
- 70 - Test Razer Blade 16 - Assassin's Creed Shadows (Akumulator)
- 71 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon (Akumulator)
- 72 - Test Razer Blade 16 - Cinebench 2024 Multi (Akumulator)
- 73 - Test Razer Blade 16 - V-Ray (Akumulator)
- 74 - Test Razer Blade 16 - Podsumowanie
Sercem notebooka Razer Blade 16 jest 12-rdzeniowa i 24-wątkowa jednostka AMD Ryzen AI 9 HX 370 z serii APU Strix Point. Za wyświetlanie grafiki odpowiada zarówno zintegrowany układ AMD Radeon 890M jak również osobny układ graficzny NVIDIA GeForce RTX 5090 Laptop GPU. Dzięki aktywnej funkcji przełączania się grafik (Advanced Optimus), do bardziej wymagających zadań aktywowana zostaje automatycznie karta NVIDIA GeForce RTX 5090. Funkcja przełączania się grafik powinna również wydłużyć czas pracy na baterii, co sprawdzę w dalszej części artykułu. Zerknijmy więc na pełną specyfikację:
Specyfikacja testowanej konfiguracji | Razer Blade 16 (2025) |
Procesor | AMD Ryzen AI 9 HX 370 (12C/24T) Strix Point 4 Zen 5 + 8 Zen 5c Zen 5: 2000 - 5100 MHz Zen 5c - 2000 - 3300 MHz TSMC N4P |
Zintegrowany układ graficzny | AMD Radeon 890M, 16 CU RDNA 3.5 |
Osobny układ graficzny | NVIDIA GeForce RTX 5090 Laptop GPU 24 GB GDDR7, TGP do 155 W |
RAM | 32 GB RAM LPDDR5 8000 MHz RAM lutowany (do wyboru także konfiguracja z 64 GB) |
Magazyn danych | 1x M.2 SSD PCIe 4.0 x4 NVMe (2 TB SSSTC CA6) Możliwość dołożenia dodatkowego dysku SSD M.2 PCIe 4.0 x4 NVMe |
Ekran | 16" 2560 x 1600 pikseli, 16:10 OLED ~400 nitów, ~100% DCI-P3, 240 Hz Samsung ATNA60DL04-0 |
Porty | 2x USB 4 typu C (40 Gbps / DP 1.4 / PD do 100 W) 3x USB 3.2 typu A Gen.2 1x HDMI 2.1 FRL 1x Czytnik kart pamięci SD 1x Audio-jack 3.5 mm |
Łączność | Wi-Fi 7 + Bluetooth 5.4 |
Kamera internetowa | Full HD + IR Sensor dla Windows Hello |
Akumulator | Litowo-polimerowy, 90 Wh |
Wymiary | 355 x 250,5 x 17,4 mm |
Waga | 2,14 kg |
System | Windows 11 Home 64-bit (24H2) |
Cena | 4499,99 USD (~19 000 złotych) |
Platforma AMD Strix Point bardziej niż wcześniej, wchodzi w segment hybrydowych procesorów, gdzie łączy się w sobie mniejsze oraz większe rdzenie - w tym wypadku Zen 5c oraz Zen 5. Działanie jest jednak inne w porównaniu do Intela, gdzie ten drugi korzysta z dwóch różnych mikroarchitekur dla rdzeni Performance oraz Efficient. Tutaj wykorzystywana jest jedna, wspólna mikroarchitektura o takim samym IPC. Mniejsze rdzenie Zen 5c zajmują nie tylko mniej miejsca, ale również pobierają mniej mocy (podczas obciążenia, gdy rdzeń Zen 5 pobiera około 3 W mocy, dla Zen 5c jest to jakieś 1,5 W), co poprawia ogólną efektywność energetyczną. Laptop ASUS Zenbook S 16 posiada układ AMD Ryzen AI 9 HX 370 z 12 rdzeniami i 24 wątkami w podziale na 4 rdzenie Zen 5 (8 wątków SMT) oraz 8 rdzeni Zen 5c (16 wątków SMT). Zegar bazowy wynosi 2,0 GHz (jest zatem znacznie niższy chociażby od Ryzen 7 8840HS, gdzie wynosi 3,3 GHz) z możliwością zwiększenia w trybie Turbo do maksymalnie 5,1 GHz. Procesor posiada łącznie 36 MB cache, w tym 24 MB cache L3 (z podziałem na 16 MB dla Zen 5 oraz 8 MB dla Zen 5c) oraz 12 MB cache L2 (po 1 MB na rdzeń). Układ Strix Point charakteryzuje się podstawowym TDP na poziomie 28 W z możliwością płynnej regulacji (przez producenta danego laptopa) w zakresie od 15 do 54 W. W przypadku testowanego Razer Blade 16, limity mocy mogą dobijać do maksymalnie 80 W, jeśli nie ma jednoczesnego obciążenia procesora oraz karty graficznej. AMD Ryzen AI 9 HX 370 obsługuje większość kodeków, w tym H.264, HEVC (H.265), VP9 czy AV1.
NVIDIA GeForce RTX 5090 Laptop GPU to topowy przedstawiciel architektury Blackwell w notebookach. Oferuje on rdzeń GB203 z 10496 rdzeniami CUDA oraz 24 GB pamięci GDDR7 na 256-bitowej magistrali, dostarczając przepustowości rzędu 896 GB/s. Układ oferuje wysoką wydajność zarówno w rasteryzacji jak i Ray Tracingu, choć o imponujących różnicach względem GeForce RTX 4090 Laptop GPU niestety nie można tym razem mówić. Układ wspiera jednak pełną formę DLSS 4, a więc nie tylko skalowania z użyciem modelu Transformer, ale również Multi Frame Generation w konfiguracjach x2, x3 oraz x4.
Razer Blade 16 został wyposażony w nośnik SSD PCIe 4.0 x4 NVMe marki SSSTC CA6 (SSSTC należy z kolei do KIOXIA / Toshiba, stąd oznaczenie KIOXIA na nadruku SSD). Dysk o pojemności 2 TB (w testowej wersji) korzysta z kości 3D TLC, a sekwencyjny odczyt i zapis wynosi odpowiednio 6800 MB/s oraz 4800 MB/s. Gorzej wygląda losowy zapis i odczyt próbek 4K, bowiem tutaj liczba operacji wynosi 500 000 IOPS w jednym i drugim przypadku. Nośnik w trakcie testów wykazywał się ogólnie wysoką wydajnością, a Windows 11 na nim zainstalowany działał sprawnie i bez zawieszek.
38
