Test NVIDIA GeForce RTX 4090 Laptop GPU w Razer Blade 16 - Mocna premiera architektury Ada Lovelace w notebookach
- 1 - Test Razer Blade 16 z NVIDIA GeForce RTX 4090 Laptop GPU
- 2 - NVIDIA GeForce RTX 4090 Laptop GPU i architektura Ada Lovelace
- 3 - Test Razer Blade 16 - jakość wykonania, wnętrze notebooka
- 4 - Test Razer Blade 16 - specyfikacja techniczna
- 5 - Test Razer Blade 16 - badanie jakości matrycy
- 6 - Test Razer Blade 16 - miejsca pomiarowe
- 7 - Test Razer Blade 16 - 3DMark Time Spy
- 8 - Test Razer Blade 16 - 3DMark Speed Way
- 9 - Test Razer Blade 16 - 3DMark DirectX Ray Tracing
- 10 - Test Razer Blade 16 - Assassin's Creed Valhalla
- 11 - Test Razer Blade 16 - Call of Duty: Modern Warfare II
- 12 - Test Razer Blade 16 - Control
- 13 - Test Razer Blade 16 - Cyberpunk 2077
- 14 - Test Razer Blade 16 - Dying Light 2
- 15 - Test Razer Blade 16 - Forza Horizon 5
- 16 - Test Razer Blade 16 - Marvel's Spider-Man Remastered
- 17 - Test Razer Blade 16 - Metro Exodus Enhanced Edition
- 18 - Test Razer Blade 16 - Red Dead Redemption 2
- 19 - Test Razer Blade 16 - Quake II RTX
- 20 - Test Razer Blade 16 - The Callisto Protocol
- 21 - Test Razer Blade 16 - Watch Dogs Legion
- 22 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon Next-Gen
- 23 - Test Razer Blade 16 - Control (RT / DLSS 2)
- 24 - Test Razer Blade 16 - Cyberpunk 2077 (RT / DLSS 2)
- 25 - Test Razer Blade 16 - Dying Light 2 (RT / DLSS 2)
- 26 - Test Razer Blade 16 - Marvel's Spider-Man Remastered (RT / DLSS 2)
- 27 - Test Razer Blade 16 - Metro Exodus Enhanced Edition (DLSS 2)
- 28 - Test Razer Blade 16 - The Callisto Protocol (RT)
- 29 - Test Razer Blade 16 - Watch Dogs Legion (RT / DLSS 2)
- 30 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon Next-Gen (RT / DLSS 2)
- 31 - Test Razer Blade 16 - Cyberpunk 2077 (Skalowanie DLSS 3)
- 32 - Test Razer Blade 16 - Dying Light 2 (Skalowanie DLSS 3)
- 33 - Test Razer Blade 16 - Marvel's Spider-Man Remastered (Skalowanie DLSS 3)
- 34 - Test Razer Blade 16 - Wiedźmin 3: Dziki Gon Next-Gen (Skalowanie DLSS 3)
- 35 - Test Razer Blade 16 - Cinebench R23 (Single)
- 36 - Test Razer Blade 16 - Cinebench R23 (Multi)
- 37 - Test Razer Blade 16 - 3D Particle Movement
- 38 - Test Razer Blade 16 - Performance Test 10 (CPU)
- 39 - Test Razer Blade 16 - Performance Test 10 (Memory)
- 40 - Test Razer Blade 16 - 7-zip (Kompresja dużego pliku)
- 41 - Test Razer Blade 16 - 7-zip (Kompresja małych plików)
- 42 - Test Razer Blade 16 - 7-zip (Wydajność kompresji i dekompresji)
- 43 - Test Razer Blade 16 - Handbrake
- 44 - Test Razer Blade 16 - Corona
- 45 - Test Razer Blade 16 - V-Ray (CPU)
- 46 - Test Razer Blade 16 - V-Ray RTX (GPU)
- 47 - Test Razer Blade 16 - Blender 3.4
- 48 - Test Razer Blade 16 - Blackmagic RAW Speed
- 49 - Test Razer Blade 16 - Visual Studio 2019
- 50 - Test Razer Blade 16 - 3DMark Time Spy (akumulator)
- 51 - Test Razer Blade 16 - Assassin's Creed Valhalla (akumulator)
- 52 - Test Razer Blade 16 - Cyberpunk 2077 (akumulator)
- 53 - Test Razer Blade 16 - Blender 3.4 GPU (akumulator)
- 54 - Test Razer Blade 16 - V-Ray RTX (akumulator)
- 55 - Temperatury podzespołów - małe i duże obciążenie
- 56 - Temperatury obudowy - małe i duże obciążenie
- 57 - Głośność urządzenia - małe i duże obciążenie
- 58 - Pobór mocy - małe i duże obciążenie
- 59 - Czas pracy na zasilaniu akumulatorowym
- 60 - Undervolting układu NVIDIA GeForce RTX 4090 Laptop GPU
- 61 - Undervolting - wydajność w grach
- 62 - Test Razer Blade 16 z GeForce RTX 4090 Laptop GPU - podsumowanie
Oprogramowanie Cinebench zostało oparte na najnowszym kodzie Release 23 (stąd nazwa Cinebench R23) przy użyciu zaktualizowanych kompilatorów i ma od teraz domyślnie aktywowany minimalny czas wykonywania (wcześniej ukryty w preferencjach). Cinebench R23 zapewnia lepszą dokładność testów porównawczych dla obecnych oraz przyszłych generacji procesorów, aby przetestować, czy maszyna działa stabilnie przy dużym obciążeniu procesora oraz czy chłodzenie komputera stacjonarnego lub notebooka jest wystarczające do dłuższych zadań. Celem jest sprawdzenie, czy użytkownik będzie w stanie w pełni wykorzystać potencjał procesora, oraz czy jego maszyna jest w stanie sprostać wymagającym zadaniom 3D podczas codziennego użytkowania.
Cinebench R23
Single Thread
Punkty (więcej = lepiej)
AMD Ryzen 7 5800H (8C/16T)
AMD Ryzen 7 5800X3D (8C/16T)
- 32
- 33
- 34
- 35
- 36
- 37
- 38
- 39
38
174
