Test karty graficznej PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB - Jeden z tańszych modeli, a okazuje się całkiem udany
- 1 - Test PNY GeForce RTX 4080 XLR8 - Wstęp
- 2 - Test PNY GeForce RTX 4080 XLR8 - Budowa i specyfikacja
- 3 - Test PNY GeForce RTX 4080 XLR8 - Platforma pomiarowa
- 4 - Test PNY GeForce RTX 4080 XLR8 - Miejsca pomiarowe
- 5 - Test PNY GeForce RTX 4080 XLR8 - 3DMark Time Spy
- 6 - Test PNY GeForce RTX 4080 XLR8 - Assassin's Creed: Valhalla
- 7 - Test PNY GeForce RTX 4080 XLR8 - Call of Duty: Modern Warfare II
- 8 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077
- 9 - Test PNY GeForce RTX 4080 XLR8 - Dying Light 2
- 10 - Test PNY GeForce RTX 4080 XLR8 - Forza Horizon 5
- 11 - Test PNY GeForce RTX 4080 XLR8 - God of War
- 12 - Test PNY GeForce RTX 4080 XLR8 - Hogwarts Legacy
- 13 - Test PNY GeForce RTX 4080 XLR8 - Red Dead Redemption 2
- 14 - Test PNY GeForce RTX 4080 XLR8 - Spider Man: Miles Morales
- 15 - Test PNY GeForce RTX 4080 XLR8 - The Callisto Protocol
- 16 - Test PNY GeForce RTX 4080 XLR8 - Witcher 3: Wild Hunt Next Gen
- 17 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (RT)
- 18 - Test PNY GeForce RTX 4080 XLR8 - Dying Light 2 (RT)
- 19 - Test PNY GeForce RTX 4080 XLR8 - Metro Exodus (RT)
- 20 - Test PNY GeForce RTX 4080 XLR8 - Spider Man: Miles Morales (RT)
- 21 - Test PNY GeForce RTX 4080 XLR8 - Witcher 3: Wild Hunt Next Gen (RT)
- 22 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (RT / DLSS 2 / XeSS / FSR)
- 23 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (RT / DLSS 3)
- 24 - Test PNY GeForce RTX 4080 XLR8 - Overclocking
- 25 - Test PNY GeForce RTX 4080 XLR8 - 3DMark Time Spy (OC)
- 26 - Test PNY GeForce RTX 4080 XLR8 - Cyberpunk 2077 (OC)
- 27 - Test PNY GeForce RTX 4080 XLR8 - Blender
- 28 - Test PNY GeForce RTX 4080 XLR8 - DaVinci Resolve
- 29 - Test PNY GeForce RTX 4080 XLR8 - Pobór mocy
- 30 - Test PNY GeForce RTX 4080 XLR8 - Pomiar temperatur
- 31 - Test PNY GeForce RTX 4080 XLR8 - Pomiar głośności
- 32 - Test PNY GeForce RTX 4080 XLR8 - Sumaryczna wydajność
- 33 - Test PNY GeForce RTX 4080 XLR8 - Sumaryczna wydajność (RT)
- 34 - Test PNY GeForce RTX 4080 XLR8 - Podsumowanie
Wśród producentów tańszych kart graficznych, dotychczasowym liderem pozostawał Palit/Gainward, okazjonalnie podgryzany przez mniejszych graczy w postaci Inno3D, ASRock czy Power Color. Jednak na horyzoncie pojawiła się groźna konkurencja dla wszystkich wymienionych, ponieważ po długich latach stagnacji PNY Technologies zwiększyło swoje zaangażowanie na rynku desktopowym. Amerykański producent przyjął bardzo agresywną politykę cenową, czego owocem jest chociażby testowany dzisiaj PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB, będący jednym z najtańszych modeli bazujących na chipsecie AD103. Jak wypada pod względem jakości wykonania, wydajności i kultury pracy systemu chłodzenia?
Autor: Sebastian Oktaba
Rodzina kart graficznych NVIDIA GeForce RTX 4000 bazuje na architekturze Ada Lovelace, która przeszła szereg usprawnień względem Ampere napędzającego serię GeForce RTX 3000. Przede wszystkim dołożono znacznie więcej pamięci Cache L2, przebudowano bloki GPC, wprowadzono jednostki Tensor 4. generacji oraz jednostki RT 3. generacji. Celem nadrzędnym producenta było zmaksymalizowanie wydajności śledzenia promieni i usprawnienie techniki DLSS. Właśnie tutaj dokonano najpoważniejszych modyfikacji, bowiem DLSS 3 będzie nie tylko upscalować obraz, ale również zwielokrotniać ilość klatek animacji niwelując jednocześnie bottleneck za strony procesora. DLSS 3 działa jednak wyłącznie na układach Ada Lovelace, ponieważ wymaga nowych jednostek obliczeniowych zintegrowanych w Tensorach 4. generacji. Zastosowano również 5 nm litografię TSMC pozwalającą upchnąć 2,5x więcej tranzystorów na zbliżonej powierzchni, a dodatkowo uzyskać wysokie taktowania. Względem poprzedników można oczekiwać 60-70% wzrostu wydajności w rasteryzacji, nawet 100% w śledzeniu promieni oraz 100-400% w DLSS.
PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB jest jednym z najtańszych modeli RTX 4080, więc chociażby z tego względu może zainteresować sporo osób szukających takiej karty graficznej...
PNY Technologies zostało założone w Stanach Zjednoczonych w 1985 roku, specjalizując w produkcji pamięci masowych i kart graficznych z układami NVIDIA. Firma miewała okresy większej lub mniejszej aktywności, mocno skupiając również na sprzęcie profesjonalnym, jednak na naszym podwórku pozostawała raczej w cieniu konkurencji. Dopiero niedawno coś wyraźnie drgnęło i dystrybucja zaczęła dostrzegać autorskie modele PNY, charakteryzujące się naprawdę atrakcyjnymi cenami przy zachowaniu nienagannej jakości. Możliwe, że dotychczas firmie brakowało jakiegoś wybitnego modelu, który zostałby gwiazdą i zamienił globalne postrzeganie marki, aczkolwiek jeszcze nic straconego. PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB zapowiada się bowiem ciekawie, mogąc stanowić swoistą przepustkę do wypłynięcia na szerokie wody popularności. Sprawdźmy czy faktycznie warto zainwestować weń swoje pieniądze...
RTX 4090 | RTX 4080 | RTX 4070 Ti | RTX 4070 | |
Architektura | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace |
Układ graficzny | AD102 | AD103 | AD104 | AD104 |
Litografia | 5 nm | 5 nm | 5 nm | 5 nm |
Rozmiar rdzenia | 608 mm² | 379 mm² | 295 mm² | 295 mm² |
Tranzystory | 76 mld | 46 mld | 36 mld | 36 mld |
Jednostki SP | 16384 | 9728 | 7680 | 5888 |
Jednostki TMU | 512 | 304 | 240 | 184 |
Jednostki ROP | 192 | 112 | 80 | 64 |
Jednostki RT | 128 | 76 | 60 | 46 |
Jednostki Tensor | 512 | 304 | 240 | 184 |
Taktowanie bazowe | 2235 MHz | 2205 MHz | 2310 MHz | 1920 MHz |
Taktowanie boost | 2520 MHz | 2505 MHz | 2610 MHz | 2475 MHz |
Taktowanie pamięci | 21200 MHz | 22400 MHz | 21000 MHz | 21000 MHz |
Ilość pamięci | 24 GB | 16 GB | 12 GB | 12 GB |
Typ pamięci | GDDR6X | GDDR6X | GDDR6X | GDDR6X |
Szyna pamięci | 384-bit | 256-bit | 192-bit | 192-bit |
Przepustowość | 1020 GB/s | 717 GB/s | 505 GB/s | 505 GB/s |
Interfejs | PCI-E 4.0 x16 | PCI-E 4.0 x16 | PCI-E 4.0 x16 | PCI-E 4.0 x16 |
Współczynnik TGP | 450 W | 320 W | 285 W | 200 W |
Cena startowa | 1599 USD | 1199 USD | 799 USD | 599 USD |
Test wydajności Diablo IV DLSS - Piekielne techniki NVIDII poprawiające wydajność. Jak to działa i wygląda?
PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB jest modelem autorskim występującym również w wariancie OC, droższym od recenzowanego ponad 300 złotych, chociaż wówczas zyskujemy tylko skromne 50 MHz więcej na rdzeniu. Poza tym, obydwa urządzenia są fizycznie identyczne. Bazowe taktowanie układu graficznego w podstawowej wersji ustawiono na poziomie 2505 MHz, zatem producent trzymał się referencyjnych wartości, natomiast rzeczywisty GPU Boost wynosi 2745-2760 MHz. Pamięci GDDR6X również pracują z fabrycznym zegarem 22400 MHz, których na pokładzie znajdziemy oczywiście 16 GB na 256-bitowej magistrali. Warto jeszcze wspomnieć, że karta graficzna PNY GeForce RTX 4080 XLR8 Gaming Verto Epic-X RGB nie pozwala ustawić Power Limitu powyżej 100. Dokładniejszy opis urządzenia znajdziecie na kolejnej stronie, natomiast producent udziela na urządzenie 36-cio miesięcznej gwarancji.
69
550
453
Test karty graficznej MSI GeForce RTX 5060 Gaming - Legendarne 8 GB niezgody. Najbardziej emocjonująca tegoroczna premiera
250
