Test karty graficznej MSI GeForce RTX 4070 Ti Suprim X - Wydajność GeForce RTX 3090 Ti, niższa cena i pobór mocy
- 1 - Test MSI GeForce RTX 4070 Ti Suprim X - Wstęp
- 2 - Test MSI GeForce RTX 4070 Ti Suprim X - Budowa i specyfikacja
- 3 - Test MSI GeForce RTX 4070 Ti Suprim X - Platforma testowa i metodyka
- 4 - Test MSI GeForce RTX 4070 Ti Suprim X - Miejsca pomiarowe
- 5 - Test MSI GeForce RTX 4070 Ti Suprim X - 3DMark Time Spy
- 6 - Test MSI GeForce RTX 4070 Ti Suprim X - Assassin's Creed: Valhalla
- 7 - Test MSI GeForce RTX 4070 Ti Suprim X - Call of Duty: Modern Warfare II
- 8 - Test MSI GeForce RTX 4070 Ti Suprim X - Cyberpunk 2077
- 9 - Test MSI GeForce RTX 4070 Ti Suprim X - DOOM Eternal
- 10 - Test MSI GeForce RTX 4070 Ti Suprim X - Dying Light 2
- 11 - Test MSI GeForce RTX 4070 Ti Suprim X - Forza Horizon 5
- 12 - Test MSI GeForce RTX 4070 Ti Suprim X - God of War
- 13 - Test MSI GeForce RTX 4070 Ti Suprim X - Horizon: Zero Dawn
- 14 - Test MSI GeForce RTX 4070 Ti Suprim X - Metro Exodus
- 15 - Test MSI GeForce RTX 4070 Ti Suprim X - Red Dead Redemption 2
- 16 - Test MSI GeForce RTX 4070 Ti Suprim X - Spider Man: Miles Morales
- 17 - Test MSI GeForce RTX 4070 Ti Suprim X - Wiedźmin 3: Dziki Gon
- 18 - Test MSI GeForce RTX 4070 Ti Suprim X - Cyberpunk 2077 (RT)
- 19 - Test MSI GeForce RTX 4070 Ti Suprim X - Dying Light 2 (RT)
- 20 - Test MSI GeForce RTX 4070 Ti Suprim X - Metro Exodus (RT)
- 21 - Test MSI GeForce RTX 4070 Ti Suprim X - Cyberpunk 2077 (RT i DLSS)
- 22 - Test MSI GeForce RTX 4070 Ti Suprim X - Dying Light 2 (RT i DLSS)
- 23 - Test MSI GeForce RTX 4070 Ti Suprim X - Metro Exodus (RT i DLSS)
- 24 - Test MSI GeForce RTX 4070 Ti Suprim X - Cyberpunk 2077 (RT i DLSS 3)
- 25 - Test MSI GeForce RTX 4070 Ti Suprim X - Overclocking
- 26 - Test MSI GeForce RTX 4070 Ti Suprim X - 3DMark Time Spy (OC)
- 27 - Test MSI GeForce RTX 4070 Ti Suprim X - Cyberpunk 2077 (OC)
- 28 - Test MSI GeForce RTX 4070 Ti Suprim X - Dying Light 2 (OC)
- 29 - Test MSI GeForce RTX 4070 Ti Suprim X - Blender
- 30 - Test MSI GeForce RTX 4070 Ti Suprim X - DaVinci Resolve
- 31 - Test MSI GeForce RTX 4070 Ti Suprim X - Pobór mocy
- 32 - Test MSI GeForce RTX 4070 Ti Suprim X - Pomiar temperatur
- 33 - Test MSI GeForce RTX 4070 Ti Suprim X - Pomiar głośności
- 34 - Test MSI GeForce RTX 4070 Ti Suprim X - Sumaryczna wydajność
- 35 - Test MSI GeForce RTX 4070 Ti Suprim X - Sumaryczna wydajność (RT)
- 36 - Test MSI GeForce RTX 4070 Ti Suprim X - Podsumowanie
Do pomiaru poboru mocy platformy testowej posłużył watomierz cyfrowy. Na poniższych wykresach krótszy słupek to wynik uzyskany przy domyślnych ustawieniach, natomiast dłuższy jest wynikiem po podkręceniu. W spoczynku karty graficzne osiągają identyczne wyniki, ponieważ znacznie redukują taktowania GPU/MEM. Wartość ta przeważnie wynosi 70-80W zależnie od zastosowanego układu, dlatego nie została uwzględniona na wykresach. Wszędzie podaję maksymalne wartości zegarów (OC) jakie osiągnęły testowane karty graficzne, natomiast przez ustawienia fabryczne rozumiem częstotliwości bazowe danego modelu.
Pobór Mocy - Cyberpunk 2077 (Cała Platforma)
Ustawienia fabryczne / Overclocking
Wat (mniej = lepiej)
1610 MHz (Base) 1920 MHz (Boost)
8 GB GDDR6 256-bit 16000 MHz
1675 MHz (Base) 2040 MHz (Boost)
8 GB GDDR6 256-bit 15300 MHz
2535 MHz (Base) 3000 MHz (Boost)
12 GB GDDR6X 192-bit 23400 MHz
1500 MHz (Base) 1980 MHz (Boost)
11 GB GDDR6 352-bit 15300 MHz
2405 MHz (Base) 2970 MHz (Boost)
16 GB GDDR6X 256-bit 25000 MHz
1825 MHz (Base) 2320 MHz (Boost)
16 GB GDDR6 256-bit 17200 MHz
1825 MHz (Base) 2380 MHz (Boost)
2025 MHz (Base) 2575 MHz (Boost)
20 GB GDDR6 320-bit 22000 MHz
1500 MHz (Base) 1950 MHz (Boost)
10 GB GDDR6X 320-bit 20000 MHz
1465 MHz (Base) 1875 MHz (Boost)
12 GB GDDR6X 384-bit 21000 MHz
1470 MHz (Base) 1890 MHz (Boost)
2269 MHz (Base) 2630 MHz (Boost)
24 GB GDDR6 384-bit 22000 MHz
2485 MHz (Base) 2985 MHz (Boost)
24 GB GDDR6X 384-bit 23600 MHz
1685MHz (Base) 2100 MHz (Boost)
24 GB GDDR6X 384-bit 22500 MHz
- 28
- 29
- 30
- 31
- 32
- 33
- 34
- 35
