KFA2 GeForce RTX 3090 Ti EX Gamer - Testy wydajności karty graficznej. Kosmiczny sprzęt za kosmiczne pieniądze
- 1 - Nadlatuje KFA2 GeForce RTX 3090 Ti EX Gamer
- 2 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Budowa i specyfikacja
- 3 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Oprogramowanie
- 4 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Platforma sprzętowa
- 5 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - 3DMark Time Spy
- 6 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Assassin's Creed: Valhalla
- 7 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Call of Duty: Black Ops Cold War
- 8 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Control
- 9 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Cyberpunk 2077
- 10 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - DOOM Eternal
- 11 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Horizon: Zero Dawn
- 12 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Mafia Definitive Edition
- 13 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Metro Exodus
- 14 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Red Dead Redemption
- 15 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Shadow of the Tomb Raider
- 16 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Watch Dogs Legion
- 17 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Witcher 3: Blood & Wine
- 18 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Control (RT)
- 19 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Cyberpunk 2077 (RT)
- 20 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Metro Exodus (RT)
- 21 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Control (RT i DLSS)
- 22 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Cyberpunk 2077 (RT i DLSS)
- 23 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Metro Exodus (RT i DLSS)
- 24 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - 3DMark Time Spy (OC)
- 25 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Assassin's Creed: Valhalla (OC)
- 26 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Red Dead Redemption 2 (OC)
- 27 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Witcher 3: Blood & Wine (OC)
- 28 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Pobór mocy
- 29 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Pomiar temperatur
- 30 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Pomiar głośności
- 31 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Sumaryczna wydajność
- 32 - Test KFA2 GeForce RTX 3090 Ti EX Gamer - Podsumowanie
Pomiar ciśnienia akustycznego wykonywaliśmy w skrzyni bezechowej o wymiarach wewnętrznych 50 x 38 x 32 cm (do czubków stożków). Ściany po obu stronach wyłożono kilkoma warstwami materiałów absorbujących dźwięk, m.in.: pianka wygłuszająca w kształcie rombów (40 mm), mata butylowo-elastomerowa (10 mm), pianka utwardzona (5 mm) oraz mata korkowa średnioziarnista (5 mm). Za urządzenie pomiarowe posłużył miernik poziomu dźwięku Brüel&Kjar Type 2203 (dynamika: 10 - 130dB), filtr oktawowy Brüel&Kjar Type 1613 (częstotliwość 31,5 Hz – 31,5 kHz) oraz mikrofon pojemnościowy Brüel&Kjar 4145 (częstotliwość: 2.6 Hz - 18 kHz, dynamika: 10 - 146 dB). Urządzanie pomiarowe posiadają klasę dokładności (1), co określa maksymalny błąd pomiarowy bliski wzorcowemu. Częstotliwość korygowana była charakterystyką A ze stałą czasową S (Slow). Pomiary wykonywaliśmy w godzinach nocnych w celu wykluczenia czynników zewnętrznych. Tło pomiaru w komorze wynosiło 17 dBA, temperatura 26 stopni Celsjusza, a wilgotność 30%. Za chłodzenie procesora odpowiadał Scythe Grand Kama Cross - spoczynek 282/306 RPM (~18,5 dB(A)), obciążenie 502 RPM (~20 dB(A)). Test podzielono na dwie części: spoczynek oraz obciążenie. W spoczynku wyświetlany był pulpit wraz z uruchomionym HWMonitor oraz MSI Afterburner. Czas pomiaru 5 minut od zamknięcia skrzyni. Po zakończeniu testu, 2 minutowe wietrzenie 30 cm wentylatorem. Za obciążenie posłużył nam Wiedźmin 3 i wybrane miejsce testowe (2560x1440 / Uber). Czas pomiaru wynosił dokładnie 5 minut od zamknięcia skrzyni i rozpoczęcia procedury testowej.
KFA2 GeForce RTX 3090 Ti Ex Gamer - wentylatory w systemie chłodzenia pracowały z prędkością ~1500 obrotów na minutę. Do osiągnięcia około 60 stopni Celsjusza na rdzeniu, cooler pozostaje w trybie pasywnym, więc urządzenie nie generuje żądnego hałasu (cewki również nie piszczały).
Poziom głośności - Ustawienia fabryczne
Spoczynek / Obciążenie Wiedźmin 3
dB(A) (mniej = lepiej)
1395 MHz (Base) 1755 MHz (Boost)
24 GB GDDR6X 384-bit 19500 MHz
12 GB GDDR6 192-bit 15000 MHz
1968 MHz (Base) 2590 MHz (Boost)
8 GB GDDR6 128-bit 16000 MHz
2044 MHz (Base) 2400 MHz (Boost)
8 GB GDDR6 128-bit 14000 MHz
16 GB GDDR6 256-bit 16000 MHz
1410 MHz (Base) 1845 MHz (Boost)
8 GB GDDR6 256-bit 14000 MHz
1700 MHz (Base) 2215 MHz (Boost)
2321 MHz (Base) 2435 MHz (Boost)
12 GB GDDR6 192-bit 16000 MHz
1560 MHz (Base) 2045 MHz (Boost)
1575 MHz (Base) 1845 MHz (Boost)
8 GB GDDR6X 256-bit 19000 MHz
1605 MHz (Base) 1830 MHz (Boost)
11 GB GDDR6 352-bit 14000 MHz
1605 MHz (Base) 1775 MHz (Boost)
GDDR6 8 GB 256-bit 14000 MHz
- 25
- 26
- 27
- 28
- 29
- 30
- 31
- 32
48
163
161
273
