- 1 - Test AMD Ryzen Threadripper 9980X i 9970X - Wstęp
- 2 - Test AMD Ryzen Threadripper 9980X i 9970X - DDR5 Kingston Fury Renegade PRO
- 3 - Test AMD Ryzen Threadripper 9980X i 9970X - Taktowania fabryczne (9980X)
- 4 - Test AMD Ryzen Threadripper 9980X i 9970X - Temperatury (9980X)
- 5 - Test AMD Ryzen Threadripper 9980X i 9970X - Taktowania fabryczne (9970X)
- 6 - Test AMD Ryzen Threadripper 9980X i 9970X - Temperatury (9970X)
- 7 - Test AMD Ryzen Threadripper 9980X i 9970X - Metodyka pomiarowa (FAQ)
- 8 - Test AMD Ryzen Threadripper 9980X i 9970X - Platforma sprzętowa
- 9 - Test AMD Ryzen Threadripper 9980X i 9970X - 7-Zip
- 10 - Test AMD Ryzen Threadripper 9980X i 9970X - Autodesk Maya
- 11 - Test AMD Ryzen Threadripper 9980X i 9970X - Blackmagic
- 12 - Test AMD Ryzen Threadripper 9980X i 9970X - Blender
- 13 - Test AMD Ryzen Threadripper 9980X i 9970X - Cinebench (ST)
- 14 - Test AMD Ryzen Threadripper 9980X i 9970X - Cinebench (MT)
- 15 - Test AMD Ryzen Threadripper 9980X i 9970X - Corona
- 16 - Test AMD Ryzen Threadripper 9980X i 9970X - DigiCortex
- 17 - Test AMD Ryzen Threadripper 9980X i 9970X - Dolphin
- 18 - Test AMD Ryzen Threadripper 9980X i 9970X - HandBrake
- 19 - Test AMD Ryzen Threadripper 9980X i 9970X - JavaScript
- 20 - Test AMD Ryzen Threadripper 9980X i 9970X - Shotcut
- 21 - Test AMD Ryzen Threadripper 9980X i 9970X - Stockfish
- 22 - Test AMD Ryzen Threadripper 9980X i 9970X - Veracrypt
- 23 - Test AMD Ryzen Threadripper 9980X i 9970X - Visual Studio
- 24 - Test AMD Ryzen Threadripper 9980X i 9970X - Cyberpunk 2077 (1920x1080)
- 25 - Test AMD Ryzen Threadripper 9980X i 9970X - Cyberpunk 2077 (2560x1440)
- 26 - Test AMD Ryzen Threadripper 9980X i 9970X - Cyberpunk 2077 (3840x2160)
- 27 - Test AMD Ryzen Threadripper 9980X i 9970X - Starfield (1920x1080)
- 28 - Test AMD Ryzen Threadripper 9980X i 9970X - Starfield (2560x1440)
- 29 - Test AMD Ryzen Threadripper 9980X i 9970X - Starfield (3840x2160)
- 30 - Test AMD Ryzen Threadripper 9980X i 9970X - Witcher 3: Wild Hunt (1920x1080)
- 31 - Test AMD Ryzen Threadripper 9980X i 9970X - Witcher 3: Wild Hunt (2560x1440)
- 32 - Test AMD Ryzen Threadripper 9980X i 9970X - Witcher 3: Wild Hunt (3840x2160)
- 33 - Test AMD Ryzen Threadripper 9980X i 9970X - Pobór mocy (Spoczynek)
- 34 - Test AMD Ryzen Threadripper 9980X i 9970X - Pobór mocy (Render)
- 35 - Test AMD Ryzen Threadripper 9980X i 9970X - Pobór mocy (Gra)
- 36 - Test AMD Ryzen Threadripper 9980X i 9970X - Podsumowanie
AMD Ryzen Threadripper 9980X i 9970X zgodnie z oczekiwaniami znakomicie spisują się w większości programów, zazwyczaj zajmując czołowe pozycje, zwłaszcza gdy zachodzi przynajmniej poprawne skalowanie z rdzeniami. Wzrosty od kilkudziesięciu do kilkuset procent względem topowych desktopowych jednostek widać między innymi w Autodesk Maya, 7-Zip, Blackmagic RAW, Blender, Cinebench 2024 MT, Corona, HandBrake, Stockfish, Veracrypt i Visual Studio. Chociaż część programów nie potrafi efektywnie wykorzystać ponad 32 rdzeni, nawet nie wspominając o większej liczbie wątków, to wysoce wyspecjalizowany software powinien dodatkowo zwiększyć użyteczność nowych Threadripperów. Zdarzają się również scenariusze, gdzie AMD Ryzen Threadripper 9970X wyprzedza model 9980X, co akurat nie powinno dziwić, bowiem gdy zawodzi skalowanie, wygrywa procesor uzyskujący wyższe taktowanie. O kondycji w grach komputerowych można z kolei napisać, że prezentuje się podobnie do zwykłych AMD Ryzen 9000, czyli naprawdę nie najgorzej, zważywszy iż mówimy o procesorach do zupełnie innych zastosowań, gdzie kwestie rozrywkowe są całkowicie poza konkursem. Zaskakująco dobrze wypada także kultura pracy - pobór mocy pod obciążeniem jest zbliżony do Intel Core i9-14900K, którego w zastosowaniach profesjonalnych AMD Ryzen Threadripper 9980X i 9970X dosłownie rozgniatają na krzemową miazgę. Zresztą, porównujemy jednostkę mającą 24 rdzenie P/E-Core do bezkompromisowego 64 rdzeniowego kolosa. Całkiem niskie okazują się również temperatury, które na zwykłym 360 mm AiO, wprawdzie hałasującym niczym odrzutowiec, uzyskują bardzo rozsądne 67-75 stopni Celsjusza pod pełnym obciążeniem. AMD Ryzen Threadripper 9000 ugruntowują więc pozycję firmy w świecie HEDT, może nie będąc wielką rewolucją, ale solidną ewolucją z pewnością. Rzecz jasna, nie jest to sprzęt dla każdego...
AMD Ryzen Threadripper 9980X i 9970X znakomicie spisują się w większości programów, przeważnie zajmując czołowe pozycje na wykresach, zwłaszcza gdy zachodzi przynajmniej poprawne skalowanie z rdzeniami.
AMD Ryzen Threadripper 9980X kosztuje ponad 22000 złotych, AMD Ryzen Threadripper 9970X około 11000 złotych, więc mówimy o bardzo drogich jednostkach, nawet biorąc pod uwagę kategorię HEDT. Dla porównania, aktualnie najlepszy procesor do pracy i grania, czyli AMD Ryzen 9 9950X3D, kosztuje poniżej 3000 złotych. Różnica w cenie jak zwykle nie odpowiada różnicy w wydajności, aczkolwiek to jeszcze może zależeć do konkretnego zastosowania. OK - dostajemy quad channel, więcej cache, obsługę 1 TB RAM, większy jest również rozmiar układu, ale ostatecznie architektura to nadal Zen 5, prawda? Litografia identyczna, zgadza się? Oczywiście, trudno to policzyć na „chłopski rozum”, a rynek profesjonalny rządzi się swoimi prawami. Komu potrzebna taka wydajność, zapłaci bez problemu, wszak kupuje w celach zarobkowych. I nieważne, że płyta główna to kolejne 3500 złotych, natomiast 128 GB pamięci Kingston Fury Renegade PRO 6400 CL32 około 4000 złotych. Wszak to drobne przy procesorze :)
AMD Ryzen Threadripper 9970X / 9980X
Cena: 11000 / 22000 zł
- 29
- 30
- 31
- 32
- 33
- 34
- 35
- 36
248
189
69
173
